NI TestStand
how to get the value field of the return parameters for an action step in teststand sequence file programatically using c#
                Sequence mySequence = myEngine.NewSequence();
                mySequence.Name = "myAction";
                //Create new step of type Action and set Name
                Step mystep = myEngine.NewStep(AdapterKeyNames.DotNetAdapterKeyname, StepTypes.StepType_Action);
                mystep.Name = "GetStringObject";
                //Obtain the code module from the step
                DotNetModule myModule = mystep.Module as DotNetModule;
                //Set properties of the module
                myModule.SetAssembly(DotNetModuleAssemblyLocations.DotNetModule_AssemblyLocation_File, @"C:\Documents and Settings\My Documents\Visual Studio 2005\Projects\HelperClass\HelperClass\bin\Debug\HelperClass.dll");
                myModule.ClassName = "Class1";
                myModule.MemberType = DotNetModuleMemberTypes.DotNetMember_GetProperty;
                myModule.MemberName = "StringObject";
                mySequence.InsertStep(mystep, 0, StepGroups.StepGroup_Setup);
                mySequence.Locals.NewSubProperty("StringObject", PropertyValueTypes.PropValType_Reference, false, "", 0);
                DotNetParameterDirections reference = mySequence.Locals as DotNetParameterDirections;
                mySequence.Locals.GetPropertyObject("StringObject", 0);
                myModule.ClassReference = "Locals.StringObject";
                myModule.LoadPrototypeFromMetadataToken(385875969, 0);
After this I am not able to proceed.herewith attached documents contain screenshot of teststand file marked red is to be solved. How to define the value field of the return parameters?
(3,423 Views)
Please see my answer to your question on page two of the following forum thread:
Programmatically generating DotNet Steps in TestStand
Manooch H.
(3,374 Views)
