NI TestStand
how to get variable implement in sheetname?
hello,
     new guy coming again.
I want to get sheetname in attached seq named by variables, so it can be renamed by expression in front of it when seq running.
how can it works? thanks!
(4,228 Views)
I just find a way to change sheetname dynamically, its to use Pre-Expression.
now the problem leads to when I have a numeric variable in expression such as <StationGlobals.ANALOG_LOAD1>, how can i change the numeric part of this variable dynamically? that is to say next step the variable should be <StationGlobals.ANALOG_LOAD2>
(4,221 Views)
