NI TestStand
how to load the shared variable of LabView
hello,
I have created a set of shared variables in lvproj, and now I want to load variables into TS, as I search on the internet, I use the step of "Deploy Libaray" to load the lvlib file, but there is no idea of how to use the variable next.
What should I do next?
Thank you
(2,652 Views)
Accepted by topic author ixlty
(2,623 Views)
carmen9
Thank U for your help. I have tried your way and get the idea that the step of "Deploy Library" can hold the work of loading the variable of lvproj, and then I can just use the vi with shared variable normally.
(2,613 Views)
how to read/write the shared variable of LabView?
please help me,thank you.
(2,078 Views)
