NI TestStand
how to make a file read only programatically
  I am updating  stationglobals.ini file by inserting 100+ variables programatically. Problem is once I insert all variables I need to set the stationglobals.ini file to read only. Can any one help me how to do that in test stand.
krishna
(3,290 Views)
This may give teststand some issues because when TestStand closes it will want to update the StationGlobals file.
Try just setting the attribute in explorer then close TestStand to see if it is going to be an issue.
regards
Ray Farmer
Regards
Ray Farmer
(3,278 Views)
