NI TestStand
how to make a histogram with NI TestStand
Hi everybody,
I'm working on several PCB testing. The analog output will be given by a VI, then several analoginput will be measured, it seems like that
PCB1
AO1=4V
(AI1,AI2,AI3,...AI8) will be measured
AO2=5V
(AI1,AI2,AI3....AI8) will be measured
PCB2
AO1=4V
AO2=5V
I want to get the data on the histogram like that
AO1=4V, the histogram shows the statistic about the AI1,AI2...AI8 of all the PCBs
AO2=5V,the histogram shows the statistic about the AI1,AI2...AI8 of all the PCBs
I know it's confused. I was wondering if the TestStand has the functions already, and I'm tried some VIs, but either never works or takes too much time.
Thank you for your help.
best regards
badstone
(3,582 Views)
TestStand does not have these functions.
You can store all the values in database (enable option) and use either CVI or LV to display it.
How are you displaying it using a VI and how much time does the VI take to display it?
(3,573 Views)
