NI TestStand
how to make "ask for number input" display when run in the middle of a sequence file of teststand ?After input, you just need to press"Enter" of keyboard, then the sequence goes on .And the number be keyed in just now will be saved to a txt file.
The best way to do this is to create a Labview program that uses a dialog box for number entry, then write the number to a text file. Then call this vi from TestStand. To try to do this in TestStand is not practical. In Labview you can check the input to see if it is a valid number, you can prompt for a filename, or check if the file exists, etc... This is what Labview is for. TestStand simply calls a sequence of vi's that do all the action.
- tbob
Inventor of the WORM Global
(3,549 Views)
I am actually doing the exact same thing.  I can now scan in a serial number and save it as a local variable.  However, when I run the sequence the prompt for input does not pop-up, it is minimized.  Therefore, I have to click on it to actually see the prompt.  Is there any way to get around this issue?  Thanks.
(3,418 Views)
Check your vi properties.  Make sure the window appearance is not set to run minimized.
- tbob
(3,412 Views)
