NI TestStand
how to modify the default result Access Table of database log in TestStand?
The default TestStand database schema requires the following tables in
your database:
• UUT_RESULT
• STEP_RESULT
• STEP_SEQCALL
• STEP_PASSFAIL
• STEP_CALLEXE
• STEP_MSGPOPUP
• STEP_PROPERTYLOADER
• STEP_STRINGVALUE
• MEAS_NUMERICLIMIT
• MEAS_IVI_WAVE
• MEAS_IVI_WAVEPAIR
• MEAS_IVI_SINGLEPOINT.
My question is how to modify the table such as STEP_RESULT. i want to delete the columns i donnot want in the table. How to do ?
(3,688 Views)
You copy the schema you want to use, make it editable and then delete the columns in the tables that you don't want. Then you create a new database file with the SQL tool and point the logging to that.
(3,680 Views)
Can you give a more detailed instruction aboaut how to do that ? Thanks a lot!
(3,653 Views)
Go to Configure -> Database Options -> Schemas.
Select the default Access schema. Click Duplicate to duplicate the schema. Then click on this new schema. Now you can freely edit it and change anything you like.
(3,627 Views)
