NI TestStand
how to obtain parameter from VC++ app and how pass parameter to VC++ app??
Hi Folks :
Now I want to know how to obtain the parameter from a VC++(i.e. :  TRUE or FALSE) file and how to pass the parameter to a VC++ app??
Could anyone help me out of that ??
Thanks in advance !
(3,605 Views)
As I am total new on this.
Any idea ??
Thx in advance !
(3,593 Views)
Andrew,
Can you give some more information of what you are trying to do.
If this is a Measurement Studio for VC++ question maybe you should re-post at this link
http://forums.ni.com/ni/board?board.id=231
Regards
Ray Farmer
Regards
Ray Farmer
(3,580 Views)
Do you mean you want to pass value through test cases in TestStand? If so, you can use Local Variables.
(3,577 Views)
Hi Ray Farmer :
First of all, thanks your fast reply on this .
What I am trying to do is just like as below :
Say :   I have created a application that base on dialog in VC++ , in that , there is a parameter pPara  that store the result for the testing (i.e. :TRUE or FALSE) , also , I have a parameter Rst_pPara in TestStand that also store the result for the testing(TRUE or FALSE), now I want to pass the value from pPara to Rst_pPara   , how to realize that ??   also , and from Rst_pPara to pPara ??
Environment :    TestStand2.0      VC++6.0     Windows2000 Pro
Any code snippet or sample here would be prefer.
Could you pls. advise ?
Thanks !
帖子被Andrew_Marc在12-19-2006 07:22 PM时编辑过了
(3,568 Views)
