NI TestStand
how to prevent LV "New Open Help Config" panel displaying during TS?
what is the easiest way to prevent LV "New Open Help Config" panel displaying or being visible during TS execution?
(2,775 Views)
Hi Stephen,
The first option you could look at is just to use the LabVIEW Run-Time Engine instead of the Development System as your LabVIEW adapter (Configure >> Adapters). This will not show the Getting Started window that pops open when you run a sequence that contains LabVIEW action steps.
The other option that you could look into is the window activation properties for each step found by right-clicking a step and selecting properties. Then select the Run Options tab and mess with the TestStand Activation Window drop down menu.
Hope this helps!
Best Regards,
Jonathan N.
(2,762 Views)
