NI TestStand
how to re-run the sequnce which is failed
Please look into attachement for Question
(2,841 Views)
Hi sonet,
I have attached an example TS2.0.x sequencefile. Is this the sort of action you are looking for?
I have modified the Callback 'SequenceFilePostStepFailure' so that the popup will only be displayed if the sequencecall fails. This example is based on the example provided in your teststand examples folder 'Callbacks'.
Regards
Ray Farmer
Regards
Ray Farmer
(2,840 Views)
