NI TestStand
how to reopen previously saved reports?
is it possible to reopen previously saved test reports in Teststand, in order to run only the previously failed tests on a UUT?
I appreciate any help.
Cheers,
Stephan
(3,145 Views)
Hi Stephan,
New to TestStand 3.5, the Message Pop Up Step type allows you to display images and webpages. Simply right click on a message pop up step and select "Edit Message Settings", then go to the "Options" tab. At the bottom there are settings for "Display Image or Web Page". You could select your previous generated reports and display them to the operator.
Hope this helps Stephan, have a good one!
Dan Weiland
www.ni.com/support
Dan Weiland
(3,129 Views)
Yea, that should be fine.
Stephan
(3,125 Views)
