NI TestStand
how to run selected sequences/steps after the great-grandparent, the grandparent and the parent sequence ?
If you just need to do this interactively for debugging purposes, just set a breakpoint in the sequence you only want to run some of the steps in. Then do a normal execution, then when you hit the breakpoint do an interactive execution. You can do interactive executions from a breakpoint in the execution document window.
Hope this helps,
-Doug
Message 11 of 12
(863 Views)
Ray,
Do you know how to have the SequenceFileLoad callback programatically copy the Main Sequence\Setup to SequenceFilePreInteractive\Setup and Main Sequence\Cleanup to SequenceFilePostInteractive\Cleanup?
This would eliminate having to manually maintain\update the Pre & Post  sequences to have the contents from the Main Sequence whenever a developer modifies the Main Sequence Setup & Cleanup.
I have tried a couple of ideas, but have not been successful so far.
Wayne
Message 12 of 12
(846 Views)
