NI TestStand
how to set TestStand run in background
I want to make a UI buy C++.and let me just watch the userInterface,how can I make TestStand run in background?
or where can I get the data? thank you!
(2,903 Views)
Sean,
the best thing you can do is to start with the provided devault UIs. If you understand how they work, you can step-by-step adopt them to your needs.
hope this helps,
Norbert
Norbert
Expert: Geometry
(2,897 Views)
