NI TestStand
how to set result of a pass/fail sequence call
OK, so you solved my example the same way as the one above.  Which I was trying to avoid.  I would like to think that I could pull in any subsequence that has the intelligence to pass or fail and use it from a higher level without modifying its parameters to pass in a passfail flag that the top level can recognise.  It is really sad that the fact that I am setting the subsequence to fail doesn't translate to the calling step that it has failed automatically.  Which is basically what it seems you were describing in your explaination as well.
"Another property of the TS.SequenceCall container is the Status.  This gets set by the engine whenever a step in the sequence fails, as long as that step has the Step Failure Causes Sequence Failure flag set.  So basically after every step executes the engine looks at its status and sets that flag when it returns to the caller.  Well that status gets passed up to the callers until it reaches  MainSequence.  Again, as long as that flag is set for all steps, including the sequence calls.  When MainSequence returns to the process model then the process model has that setting in the resultlist and knows how to handle it during the report generation stage."  -- Jigg
Oh, well.  Pushing forward.
Thanks again for all your help.
Jeff
Message 11 of 16
(2,359 Views)
Jeff,
That only applies if the step is a Sequence Call and not a Pass/Fail Test.  I've revised the code to demonstrate this.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
Message 12 of 16
(2,355 Views)
There is a huge difference between a Sequence Call step type and a Pass/Fail Test step type using the Sequence adapter.
jigg
CTA, CLA
testeract.com
Message 13 of 16
(2,354 Views)
All of this was super helpful to learn.  But it seams it still doesn't get me past my specific scenario.
The errors I'm hitting in my real code are actually RunTime Errors.  Which keeps the steps in the lower-level sequence from running Post Expression.
Back to the drawing board.
Jeff
Message 14 of 16
(2,335 Views)
There is a difference between an Error and a Failure.  The engine treats them differently.  Start a new thread and put what error you are seeing and we'll see if we can figure it out.
jigg
CTA, CLA
testeract.com
Message 15 of 16
(2,334 Views)
Message 16 of 16
(2,324 Views)
