NI TestStand
how to set up a case statement to take multiple values in teststand
I am using a select with multiple case statements.  I am using one of the case statements to be used for multiple expression results.  Specifically, the expression is a string and I want the same case to operate for values "1" and "4", but I can not find the syntax for this, does anyone know it?
(15,113 Views)
Does the example UsingFlowControlSteps.seq in the TestStand Examples\SequenceFlow help in any way
Regards
Ray Farmer
(15,109 Views)
Not really.  I am wanting to know how I could make the same case sequence occur if either "1" or "2" was the expression.  I am looking to reduce code rewriting for the same result that comes from multiple expressions.
(15,107 Views)
try this example.
Regards
Ray Farmer
(15,099 Views)
I think you just need to put your values into an array like this...
{"1","2"}
(12,467 Views)
In your question you include two string representations of numbers:  "1" and "4".  In addition to discrete numeric, character and logical expressions, the TestStand case statement also allows for arrays of either strings or numbers to be used when a single case needs to match more than one expression result.  Syntax for these arrays is:
    case {expression_1, expression_2,...,expression_n}  //matches any of the expressions contained in {...}
Where expression can be a numeric value or a string value.
    case {"string_1", "string_2"}
and
    case {1,2,3,4,5,6,7,8}
are both legal case arrays
There is no limit on the number of expressions.
Note, unlike some extensions of the C switch:case statement, case ranges such as 5:20 (matching any value from 5 to 20) are not legal.  case arrays can only contain a number of discrete expressions
An example showing a numeric array can be seen in the PromptForInput sub-sequence on the second case statement <teststand directory>\Examples\Built-In Step Types\Message Popup Step Type\Message Popup Step Type - Get User Input.seq
(C:\Users\Public\Documents\National Instruments\TestStand YYYY (32-bit) is a typical path for <teststand directory>)
(7,536 Views)
I tried entering an array of numbers, but it gave an error that it could not compare an array of numbers to the selection, which was a single integer.
(5,024 Views)
