02-10-2006 01:40 PM
02-13-2006 06:57 PM
02-13-2006 11:48 PM
02-14-2006 06:53 PM
02-15-2006 09:00 AM
Hey Michael,
That is almost exactly like the one we were using to reproduce the issue. I had reproduced it yesterday and am in the process of talking to R&D about the issue. I will post as soon as I come up with an explanation.
02-15-2006 02:45 PM
02-15-2006 06:00 PM
Hey Michael,
First let me address your message popup. I don't think that is working for you. If you remove the message box and then run your sequence and then click outside of TestStand and then back into TestStand you will still get the warning.
I don't understand why you are calling the SaveFileIfModified method. You can just call the IncChangeCount and be fine. I tested it by adding a user from to TestStand and I didn't get the message. And it added the new user. So if you get rid of the SaveFileIfModified and ReloadFromDisk then you will be set. I hope that helps.
02-24-2006 12:20 PM
02-24-2006 03:51 PM
Hey Michael,
It's good to finally hear from you.
Unfortunately there isn't a way to turn off both of the warnings. This is a vital part of TestStand. If this did not pop up and give the user the option to accept or reject that the .ini file had been changed then you could run into race condition issues. Say for instance you modify the .ini file and haven't accepted the changes and then someone else changes the .ini file as well. You could run into issues.
I hope this helps.
02-24-2006 04:27 PM
