NI TestStand
how to transfer a string from sub sequence to main sequence
How to transfer a string from sub sequence to main sequence, My main sequence has included a sub sequence, the sub sequence is return a string value after running done, I need to get this string value from sub sequence to main sequence, I check the defined that look like seem the two
sequence have themself local variable,but I don't know how to defined a globe variable to cover main sequence and sub sequence like VC++'s Main App ,Please kindly help me,thanks in advance...
(3,481 Views)
I hope this small example will help you.
Regards
Ray Farmer
Regards
Ray Farmer
(3,477 Views)
I'm sorry,My current TS version is 3.1 ,cannot read the 3.5 version you sent sequence file,^_^
(3,472 Views)
try this.
regards
Ray Farmer
Regards
Ray Farmer
(3,461 Views)
well, it solved my question,thanks.
(3,444 Views)
