NI TestStand
implement custom error code in teststand
my labview vi returns an error code
& on that basis can i generate an  eror  message
these error messages are to be read from a file like in labview (error codes)
I dont want to code the individual step to show that error message.
if its handled  subtly at a  higher level  tht wld be gr8
(5,071 Views)
You can use a simple way to address this.
Insert the "General Error Handler" in your VI. If you don't want the VI to display the error dialog on its own, pass "no dialog" as "type of dialog" option to General Error Handler.
Pass the "message" you receive from General Error Handler to TS as errormessage.
Norbert
Norbert
Expert: Geometry
(5,068 Views)
have tht already implemented
but does teststand   provide any such   quick trick
(5,058 Views)
No
At least, i am not aware of something like this.
Norbert
Norbert
Expert: Geometry
(5,054 Views)
