NI TestStand
import position with VBA
I use an Excel add-in to import some data from a tdms file. In the add-in description is explained how I copy this data to my excel sheet.
http://www.ni.com/example/10207/en/
But the maximum number of rows is greater than 2000000 in this tdms file. The important values are near the maximum value and I only need a part of the whole values. Is it possible to define the first import position with VBA?
(2,877 Views)
I would like to ask you to chcek this TDM Excel Add-In Tool for Microsoft Excel User Guide. The way how to start importing from the certain point of TDMS file is over there.
Is it what you are looking for?
(2,819 Views)
this could be what you are looking for in VBA: TDM Importer Excel start index automation.
Let me know if this helped?
(2,818 Views)
