NI TestStand
insert a local variable using the TestStand API
I've created some Global Variables using the ActiveX Adapter of TestStand. How can I insert local variables in my sequence? And an array? And how can I delete all this stuff? I'd like to create at the beginning of the sequence a lot of variables and at the end remove all. Some ideas? Thanks in advanced,
Angel
(4,581 Views)
Here you can find an example how to insert an array in the local variables:
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3EB9B56A4E034080020E74861&p_node=DZ52194
You can delete variables with the method "DeleteElements" of the PropertyObject Class
Hope this helps.
(4,581 Views)
Hi Andre,
Thanks a lot, but I want to manage this only with an ActiveX action from the TestStand API operator interface. If you have some idea, please let me know.
Angel
(4,581 Views)
I have attached an example creating an Number and Array of Numbers using API calls.
You dont really need to delete them at the end because the SequenceFile has not been set to indicated that the file has changed and therefore the variables are only available during execution.
But I have put an example of deleting the array in the cleanup.
Hope this helps
Ray Farmer
Regards
Ray Farmer
(4,581 Views)
Hi Ray,
This is exactly what I need. Thank you very much!
Angel
(4,581 Views)
