NI TestStand
insert test parameters using standart GUI controls
Hi
I work with teststand and cvi 8.0 and I  need to create gui interface for inserting parameters for test. I need to do it at creation time and not in run time.
Moreover, sequence creation for teststand need to be easy so I need to do all work in the code.
How can I run gui module at creation time and transfer parameters to test without editing things in teststand gui.
(3,164 Views)
Have you looked at the TestStand Sequence Builder example in TestStand\Examples folder as a start point.
Also there is an help in the Programmer Reference on building an application using the API.
Regards
Ray Farmer
Regards
Ray Farmer
(3,156 Views)
