NI TestStand
is it possible to terminate the execution during runtime without pressing the stop button in UUT inforamtion diaolg
Hi Alagar,
Try attached Example:
RunState.Execution.Terminate()
Greetings
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
Message 2 of 8
(3,961 Views)
Hi...
What do you actually mean by terminate during execution...?
Does that mean terminating programatically or by user...?
Programatically you can terminate by using the Test Stand API... or You can use the corresponding properties and methods in LabVIEW...
Manually You can terminate by using terminate and abort button if you are running in debug mode... i.e with tracing enabled...
Message 3 of 8
(3,960 Views)
hi J-dodek....
i hav try that but after that it asks for Continue Next UUT? or Terminate....
but i want that dialog also to be disable...
is there any way....
Message 4 of 8
(3,948 Views)
Hi Lord...
I asked abt terminating the execution programatically.....
for that i want one thing what j_dodek have expalined ....
Message 5 of 8
(3,946 Views)
Hi Alagar,
Check out the example
Hi have overidden the PreUUT and ProcessSetup Callback for  doning this
Greetings
Juergen
--Signature--
Message 6 of 8
(3,937 Views)
I have just seen you also want to disable the Terminate - Message
Override the PostUUT callback and place the if around the NI -stuff.
greetings
juergen
--Signature--
Message 7 of 8
(3,935 Views)
thanks J_dodek.....
Message 8 of 8
(3,920 Views)
