NI TestStand
list sequences
I've tried to connect an invoke node in LV OI to the application manager object, and select in this way the method OpenSequenceFile. With this method I couldn't load sequences programmatically, do to errors 17500 or 17501. I would appreciate any help in the use of this method and where to place it.
(3,599 Views)
Is this solved now?
(referring to link http://forums.ni.com/ni/board/message?board.id=330&message.id=14813#M14813 )
Regards
Ray Farmer
Regards
Ray Farmer
(3,571 Views)
Hi ray,
if you reffer to the errors 17xxx I was having, yes, are solved. In my answer to Andre, I explained to other user which and why it was not working.
Thank you
JL
P.S.: Ray, ho do you pick the URL of a specific answer/reply and paste it on the reply?
(3,566 Views)
Hi JL,
I just open that specific page, in a new window, then select the Address from the toolbar, if it's not already highlight, then press Ctrl-C to copy the selected address. Then I use Ctrl-V to paste the address into the Message window of the response I am answering.
I hope this is clear. Happy Cut & Pasting.
Ray.
Regards
Ray Farmer
(3,563 Views)
Hey Ray,
yes, I know that way, my question was oriented to see if there was a button o something else into the forums page that allow you to directly paste the addressed mail, if not, it should be usefull.
bye
JL
(3,560 Views)
