NI TestStand
loading a separate StationGlobals file
I've got a case where I have a running TestStand execution (happens to be TS2012)
I have a separate StationGlobals.ini file from ANOTHER computer/station/instance (is in a different location on harddrive with different file name, eg Station2SG.ini)
I want to be able to load Station2SG.ini into a propertyobject in TestStand (but not actually load into and overwrite my existing StationGlobals.* of my current execution -- I just want to interrogate the values in the file.
Unfortunately the file is NOT the simple xml or ini file that I could read with another utility and parse values out, and I'm stuck with that format.
Any suggestions for how to load the values of that file into PropertyObject.*?  I've tried ReadPropertyObjectFile() but that doesn't work for StationGlobals files.
(5,261 Views)
Not sure if this will work for you but you can trick it.  Change the path and then change it back.
Just a thought.  Check out the example.
You will need to change the NewPath in the Set File Paths step.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(5,242 Views)
I tried this with the existing stationglobals.ini.It should work with other stationglobals.ini files also.
1) Insert a statement step : (locals.file is a object ref type)
Locals.File = RunState.Engine.NewPropertyObjectFile(FileType_PropertyObjectFile),
Locals.File.AsPropertyObjectFile.Path = RunState.Engine.GetTestStandPath(TestStandPath_Config) + "\\StationGlobals.ini", //Change path
Locals.File.AsPropertyObjectFile.ReadFile(ConflictHandler_Error), // loads the configuration file properties
2) To read/access a value do this in a statement :
Locals.str=Locals.File->Data.StrStationGlobal_1  //  StrStationGlobal_1  is a string in my stationglobals
Hope this helps.
Ravi
(5,213 Views)
Thanks to both -- I got both methods working.
Thanks!
(5,201 Views)
Ravi's method is safer.  Then you don't have to set the station globals back.
jigg
CTA, CLA
testeract.com
(5,197 Views)
