NI TestStand
lock a sequence in teststand from opening
Is there any possibility that a sequence created can be locked from opening like locking a LabVIEW vi from opening.
(3,731 Views)
You can lock a sequence as not viewable. Is that what you mean? It will still be openable, but will require a password to view the contents.
Look on the advanced tab of the sequence file properties dialog. You should see a password setting section. You can lock it as not viewable or not editable.
-Doug
(3,723 Views)
Accepted by topic author Sury@
thank you ,i got it.
(3,710 Views)
