NI TestStand
login TestStand Operator Interface from command line
When your running the Operator Interface executable, is there a way to use the last login or a canned login to bypass the Login pop-up window?  I did not find any User Interface Startup Options for this.
(1,139 Views)
OI does not implement the login options, it is handled by the FrontEndCallback.seq present in the TS Public directory. If you would like the auto-login feature, you've to modify the FrontEndCallbacks.seq
Please refer to this article - https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHQOCA4&l=en-US
Santhosh
Soliton Technologies
(1,120 Views)
