NI TestStand
loginlogout won't close
Someone changed the Teststand configuration on my workstation and now when I start teststand and login, the sequence window for loginlogout stays open even though it is finished running (the window is dark grey and the title bar says "LoginLogout - FrontEndCallbacks.seq [1] [Completed - Passed]").   What setting do I change to make this window go away after logging in?
(2,940 Views)
Make sure Station Options>>Execution>>Trace into Separate Execution Callbacks is unchecked.
(2,936 Views)
