NI TestStand
logtodatabase fileglobals parameters or locals
I want to log in the database  my fileglobals etc.
to the best of my knowledge there is no straight forward way to acheive this (want to avoid using StationGlobals -  which works)
even if i use the LogtoDatabase callback,  I cant enter  parameters & later select them in  the Configure  Database tool.
the Only  way around was modifying the NI_Databaselogger.seq file . (i am just getting  started )
(4,532 Views)
Why don't you just add an additional results step and put them in there?
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,526 Views)
Thanks jigg,
the thing is  I  have a custom   UUT_RESULT  field   & I save only the UUT Result    (Database Options->  Apply to-> UUT Result )
& in this I need to save some FileGlobals.Variables
had it been Step result or Property result - adding  additional results would have helped.
(4,509 Views)
