NI TestStand
looping does not work when running multi up
I am trying to run a loop on a sequence if it fails, this is while running 4-up testing. I am able to go through the loop on a failure when i only run one unit but running multiple units seems to be an issue, if one unit fail the looping never occurs. i tried playing with the synchronizing settings but had no luck. wondering if there is some other setting i might need to set as well.
Thank you in advance for the help.
(1,074 Views)
Can you share a simple test sequence which can reproduce this issue.
Also indicate process model are you using
Ravi
(975 Views)
