NI TestStand
loss of labview step references in teststand
My technician was working on updating some steps in a teststand sequence and when he went to run the test again, he noticed an error when steps that were supposed to run labview have suddenly not showed labview as the chosen adapter and when we choose the labview adapter, we have to reset all module settings.  Is there a way to get them all back without having to go through the entire process again?
(3,489 Views)
I highly recommend using a source control provider of some sort. Then you will have a history of revisions of the file. If this is TestStand 4.0 or newer and the file was never closed, maybe undo would work.
-Doug
(3,473 Views)
