NI TestStand
lvclass Object Reference Value
What parameter value is passed to the lvclass object. TS is looking for an Object Reference Type.
(2,927 Views)
I'm starting to think the Object VI "Open Visa connection" doesn't really need a control lvclass on the connect pane. I could just disconnect the lvclass from the VI input which is the same as changing the lvclass to a constant, where its only on the LV block diagram.
The lvclass dat has 2 items, an ethernet alias name e.g. "SigGen" as setup in MAX and string "model number".
But at some point I'll need to pass a lvclass reference from TS.
(2,880 Views)
How do I interface a LVClass to a TestStand Object Reference?
Looks like I never got any response on this question.  A VI has a LVClass control, TS is looking for an Object Reference to interface with the LVClass.
The only thing I can think of is use a VI that has the object as an output (creates the object) and read that object as a reference into TestStand where it can be used as a reference on further TS steps.  Is this correct way of doing this?
(2,346 Views)
The shipping example (<TestStandPublic>\Examples\Fundamentals\Calling Dynamic Dispatch VIs) shows the use of a LV Class with TS.
Anand Jain
NI
(2,343 Views)
Did you notice that if you Bundle or Array LV2020 Objects, TS2019 converts these to numerical type.  I could not find a way to cast a numeral type to Object Ref.  I wanted to painlessly input many LV Objects into TS without doing any type conversion. I don't see a way to do this as yet. I only have 3 LV Objects for this task but it may not be only 3 LV Objects next time.
I was expecting TS to have a LV Object Ref as a built in type whether its an array or wire-bundle LV Control/Indicator.
Before looking at the shipping example, I did exactly what the example does - I read in each (i.e. 3) LV Objects into a TS parameter.  The shipping example used a Local Variable to read 1 LV Object.
(2,324 Views)
I do not see the issue of LV Class References showing up as numbers in TS. Here is what I tired.
Can you post an example showing the issue with LV class References show up as number in TS?
Anand Jain
NI
(2,314 Views)
Oh I forgot to mention it is a Dynamic Call VIs. Make your LV Object dynamic call.
Thanks for the response.
(2,310 Views)
