NI TestStand
main sequence disable in report generation
How to disable the path comming on the test report.
please see the attachment for clear understanding
(3,439 Views)
For the HTML report you will need to customize reportgen_html.seq
In this sequence the callback "AddSequenceResultToReport" has a step "Add Sequence File Path".
Although I have not tried but see if this helps to remove the path from report.
CLD
(3,155 Views)
What version of TestStand are you using?
In TestStand 2012, the location is actually in the AddSequenceResultToReport_Impl sequence.  You would need to comment out the following lines:
I have also had requests to do this to save space on the report,  but I accomplished this on a text report.
Good luck,
PH
(3,145 Views)
