NI TestStand
mesa.dll could not be loaded
Before I deinstalled everything from NI inlcusive Paket Manager, so I could do a fresh install ofTeststand 2025Q3 (ni-teststand-2025_25.5.0).
When I go to Configure->Result Processing I'll get the following error message:
(97 Views)
Can you confirm that Visual C++ Redistributable 2015 64-bit is installed on your system?
(88 Views)
Yes, VC was installed.
I solved the problem, I started the repair function in the paket manager for LabWindows/CVI, afterwards the bug was gone.
(71 Views)
