NI TestStand
message popup add more buttons than six
On TestStand 4.2.1, I encounter a limit of 6 buttons.
How can I add more buttons ?
Or, can I replace message popup by list ?
Thank you
(4,161 Views)
Have you thought of using LabVIEW to create something?
I have attached a simple VI that you can pass an array of string data from TestStand to LabVIEW..
Shane.
(4,153 Views)
I am using only TestStand
(4,113 Views)
That is unusual. Normally another development environment like LabVIEW, CVI, or .NET is used along with TestStand to interact with intrument drivers and custom code modules. If that is not an option, one idea is to use two message popups, label one of the buttons something like "More Options..." and if that button is pressed, bring up the secondary dialog.
Hope this helps,
-Doug
(4,088 Views)
