NI TestStand
missing DMM library - recurring problem
I posted this in the LabVIEW forum, but TestStand is involved so I thought this forum might be appropriate as well.  Could TestStand be causing this problem, or simply be sensitive to something that's happening on my computer?
Jim
Message 1 of 10
(5,085 Views)
So was the KB any help to you.
Has there been any updates that have been run on your system that is affecting the NI-DMM?
Regards
Ray Farmer
Message 2 of 10
(5,080 Views)
I responded to the other post.  I don't think it applies.
No.  This ATE and another one just like it have been running for two years.  Neither has received any NI upgrades and both get the same OS/network upgrades.  Only this ATE has the problem. I keep wondering if there's something failing on the hard drive, but I don't know anything about that.  It doesn't seem that I'd only get this one problem if hardware was dying.
Jim
Message 3 of 10
(5,053 Views)
Hi Jim,
Jeff's suggestion of attaching MAX technical reports for the two ATEs would be helpful. Upload them and I'll look into it for you.
Sean Ferguson
Application Engineering Specialist | RF and Reconfigurable Test
Message 4 of 10
(5,031 Views)
Jim,
That's the problem with posting in two different areas.
If you haven't change any software and you haven't change any hardware and its been running fine for some time, then maybe your DMM device has an intermittent fault.
Regards
Ray Farmer
Message 5 of 10
(5,022 Views)
 [...] maybe your DMM device has an intermittent fault.
How would that cause LabVIEW to fail to find the library?
Jim
Message 6 of 10
(5,016 Views)
Quite, but you are saying that the software hasn't changed / updated. Therefore it's hardware or finger trouble (eg someones deleting files/ folders).
Regards
Ray Farmer
Message 7 of 10
(5,010 Views)
Do you think it could be the hard drive?
Jim
Message 8 of 10
(5,008 Views)
Hi Jim,
This sounds like a software issue so I think the best way to determine what exactly is wrong would be if you uploaded a MAX technical report. Ideally, one from the working computer and one from the one giving you problems
Sean Ferguson
Message 9 of 10
(4,977 Views)
Hi Sean,
Here are the technical reports.  The ATP file is from the ATE that is working, the two MTP files are from the ATE with the problem.  I made one in the "broken" state and one after I "fixed" it by repairing the DMM installation.  This problem has recurred twice since I first posted; something is getting worse.
Thank you,
Jim
Jim
Message 10 of 10
(4,965 Views)
