NI TestStand
monitoring process
I'm really new to Teststand so please excuse me.
I am building a sequential test with LabView based steps.
I need also to have a process (vi) running all of the time to monitor the health of the DUT, if it goes outside parameters, then the power should be removed & test aborted.
I have invetisgated "Run Async VI" and also read on the forums about using a sub-sequence.
In my experiement with Async VI i was not able to see how to pass variables into the VI (Module tab is missing) or take pass/fail output.
And i not not fully understand how to make a sub-sequenece.
Could someone please tell me which is the best solution, and walk me through the implementation?
Thanks.
Labview 2010, TestStand 2010
(2,830 Views)
Hi
the following should help get you started:
List of Examples
sequence in parallel
code module in parallel
Regards
Ray Farmer
(2,828 Views)
