NI TestStand
multithreading in teststand
Hi everyone,
I need to read an analog value from an output continuously and in other steps this value will be used. So it is important to read the value continuously.
Is it possible to run the step that read the analog value, separately and always?  I wanted this step and reading the analog value to run as seperate thread everytime Like multithreading in other programming languages.
Thanks for advanced for your help.
(1,766 Views)
Accepted by topic author navid.mo2
You can call a sequence in a new thread or use step type to run a vi asynchronously.
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(1,711 Views)
Thank you so much for your reply. It works.
(1,682 Views)
