NI TestStand
need a conversion number to string
Hello I need a function in teststand which converts a number to string. (the opposite of the function Val() which converts a string to a number)is such a function available in Teststand? I can't found such a function
regards
Samuel
(3,210 Views)
Hi Samuel,
just use Str(), this converts a property value to string.
Regards
Steffen
(3,206 Views)
You will find Str() in the Expression Browser under the function tab.
Regards
Ray Farmer
Regards
Ray Farmer
(3,202 Views)
thanks to you all,
I have solved the problem according to your advice
regards
samuel
(3,185 Views)
