NI TestStand
no response from Teststand when trying to copy a large 2-D data in Local context.
  Attached is an example. When trying to copy a large 2-D data in local context "InOutArray", Teststand will run into no response. Is that a bug in Teststand?
Thanks!
Jacky
(3,285 Views)
Jacky,
Can you attach your example.
Regards
Ray Farmer
Regards
Ray Farmer
(3,282 Views)
Oh......I made a mistake and forgot to attached the file.
Please see attached file and find the arrary in context of "Locals.InOutArray"
THANKS
JACKY
(3,274 Views)
Jacky,
I tried to copy the 2D array [0..36491][0..3] and it takes  8 minutes to accomplish this operation on my computer (P43.39 GHz).
I guess it seems that TestStand hangs because of the time it takes to finish copying.
I'll report this issue to the R&D group.
It is pretty rare for somebody to be using an array that long though. I would like to know more about your use case in order to come up with an
alternative solution.
Best Regards.
Antonio Lie.
Message Edited by Antonio Lie (NI) on 07-26-2006 03:56 PM
(3,244 Views)
