NI TestStand
no update on connected caption
on my TS customized UI I have connected a caption to a TSUI Label Control. First I connected the "CaptionSource_UUTSerialNumber", and the control stayed empty, while my test ran through without problem. Then I changed the CaptionSource to "CaptionSource_CurrentSequence" to see what is set to this caption. I run my TestUUTs, and I see "LoginLogout" in the caption of my label....
So it seems, that after running the front end callbacks, the captions will be either not anymore connected, or not updated. What can be the root cause?
regards
Madottati
(3,503 Views)
did you use the ExecutionViewMgr to connect the caption? If not:
http://zone.ni.com/reference/en-XX/help/370052K-01/tsuiref/reftopics/applicationmgr_connectcaption_m...
If this was not the issue, please provide more data (Screenhots, etc.) on how you've connected the caption.
Kind regards
Heinz
(3,480 Views)
(3,478 Views)
