04-30-2020 08:38 AM
So I need to search for "Action" type steps in my sequence.
For local search I check "Type Names" and write "Action" in find field - this works.
but for find/replace in files when only "type names" is checked in Filter tab then it does not work. I have to check also "Steps" in Object to Search element (also it does not work when only "steps" are checked and "type names" unchecked). I can see the reason for that If I can combine "type names" with "Variables" and search for all Variables with type for instance "Number", but it does not work 🙂
detail, but maybe would be good to improve it.
05-01-2020 12:31 PM
There is a TestStand Idea exchange where you can propose changes to TestStand: https://forums.ni.com/t5/NI-TestStand-Idea-Exchange/idb-p/teststandideas
I know the folks at NI check this and rate the ideas based on community support and kudos.
Hope this helps,
