NI TestStand
number compare 0
I have noticed something peculiar in TS 4.1.
When I have a small number, like 1e-14, the following comparisons hold in an expression:
  • Locals.VerySmallNumber == 0 -> False
  • Locals.VerySmallNumber == 0.0 -> False
  • 0 == Locals.VerySmallNumber  -> True
  • 0.0 == Locals.VerySmallNumber  -> True
I might have understood the (0 == ...) bit as some implicit C-style data type conversion as the statements in general have C operator syntax, but 0.0 in C would be a double literal and therefore should compare False at that precision level. But apparently it depends on sequence?
  • Is that behavior by design?
  • Is that true in all TestStand versions?
  • Is there a way to enforce a comparison with double precision regardless of the sequence (This is perhaps a weird hangup, but we like to have the constant as the point of comparison in front of the operator to avoid the stupid "Variable = 0" instead of "Variable == 0" mistake)?
See the attached sequence file
Peter
(3,327 Views)
Accepted by topic author pwaszkewitz
Floating point comparisons in TestStand are performed at approximately 14 decimal digits of precision.
However, there is a known inconsistency that applies only to comparisons between a number that is EXACTLY zero and a very small number that is approximately 1e-14 or less. In this case, whether TestStand considers the numbers to be equals depends on which side of the comparison the exact zero is on.
This will be fixed in a future version of TestStand.
(3,312 Views)
Thank you for the clarification.
Peter
(3,306 Views)
