NI TestStand
odbc connection
Hello, I am having problems establishing a data link with an Oracle DB. I have already created an ODBC data source with MS ODBC Administrator and have successfully tested the connection. However when I setup my connection in Test Stand using the same data source name and user name and password, I get an error (see attachment). Can anyone help?
(3,404 Views)
Hi JulesG,
Are you using a system or a user DSN, or are you connecting by some other means? Also, as this is an Oracle error, this link may be helpful.  I would recommend walking through the troubleshooting steps discussed in that link if you have not done so already.  Lastly, if you are still having this problem please respond with more details so we can try to replicate this error on our end.
Cheers,
Kelly R.
(3,363 Views)
