NI TestStand
opening Teststand XML file in Internet Explorer
I have TestStand 4.1 installed on my PC.
The test station PC has TestStand 4.0 installed.
When I open the XML report file in Internet Explorer on my PC, I just get run-on text.
What am I doing wrong?
(3,495 Views)
What do you mean with "run-on text"?
If you refer to the XML content (including the tags, "raw XML"), then the Internet Explorer fails to display the content of the XML using the style sheet.
Another option is that you configured the Internet Explorer to always display the raw content instead of using the style sheet.
Norbert
Norbert
Expert: Geometry
(3,483 Views)
