NI TestStand
ordinal 18 NIVISV32.dll
Hi
I am running TestStand 4.2.  My sequence was running fine but just today I inexplicably began to get the following error:
The ordinal 18 could not be located in the dynamic link library NIVISV32.dll.
Does anyone know how to fix this?
(7,510 Views)
Check out http://digital.ni.com/public.nsf/allkb/3A00A30FCF547C7B862570F20069C3C6
It's not the same value as you have quoted but it's probably relevant. Basically you need to make sure you are working with the correct version NI-Visa.
Regards
Ray Farmer
(7,506 Views)
