NI TestStand
output pane
I am modifying the LV Full Operator Interface for Teststand and would like to add the Output Pane to the OI but I can not find a controll for it. I have found the Report Pane, Sequence Pane, and Execution Pane, but no Output Pane, where do I look for this controll?
(using LV 8.5 and TS 4.0)
Thanks in advance
Twyman
(3,124 Views)
The output pane control is not provided currently.
You will have to use your own controls and populate it manually.
Allen P.
NI
(3,123 Views)
AllenP
Thanks for the quick reply, and that would explain why I can't find it.
Twyman
(3,119 Views)
