NI TestStand
packed libraries taking long time to load
HI all,
I just upgraded my development machine to the most recent patch for Teststand and was wondering if anyone else is experincing extra load times for packed libraries for loading of modules.  I have a few packed libraries that are quite large and can take up to 5 minutes to load now.  Previously only the first load took awhile, then eveything would be fine.  Now every time I click on a sequence TestStand attempts to reload the packed libraries over and over again.
I also noticed that distribution execution with the new patch takes considerably longer as well within just the run time environment.
Any one else seen this issue with the most recent TestStand update?
-Andrew
(4,373 Views)
What patch and version of TestStand? How are you loading the packed libraries exactly?
-Jayk
RF R&D
(4,348 Views)
I'm seeing the same thing, all my code is in different PPLs and takes long time (80 secs) to load. I'm using LV2013 and TS2013. Any thoughts and what I can do to reduce the load time? Execution seems OK, is just the load time...
(4,173 Views)
