NI TestStand
parallel execution thread prints
hi,
I want to run steps in parallel mode, so i am using sequence call- > use new thread option in teststand
my question is how to identify in the TestExec engine, the 2nd thread prints inside exViewMgr_TraceEvent
so that i could control this thread prints
(2,630 Views)
my general intention is to control when i print to log the 2nd thread "test start" "test end" notifications..
(2,624 Views)
Hi Oric,
Thank you for posting to the forums!
I am a little bit unclear on your question, but I think you are talking about the Result Collection options in TestStand. This article has a lot of good information on where the results are logged and how to customize this process. I would particularly check section 2, Result Collection:
Best Practices for NI TestStand Report Generation and Customization: https://www.ni.com/en/support/documentation/supplemental/08/teststand-report-generation-and-customiz...
If this does not answer your question, if you could add a picture of what you are looking at that would be helpful!
Thanks!
(2,580 Views)
