NI TestStand
parallel testing inteststand
I am a beginner in teststand. I am trying to write a sequence of parallel tests. There are some examples in teststand that use the same test sequence (same test steps) to test multiple UUTs. However, I encountered a problem. Simultaneously test 4 UUTs in a test sequence (the test items of the 4 UUTs are the same), and one of the test items needs to share one meter, which requires a switch to switch. The switch resources used by each UUT are different. How to use the same sequence to test 4 UUTs?
Thanks!
(1,541 Views)
Accepted by topic author tidri
In the sequence you can check the value of RunState.TestSockets.MyIndex to see which socket the sequence is executing for.
(1,501 Views)
