NI TestStand
pass char array to c++ DLL and return same char array
Lectori Salutem,
Here is the situation:
Im learning TestStand, and to learn the basics, I want to do the following:
Call a (C++) DLL in TestStand with an array of chars.
The DLL should return the array of chars (or a pointer to the datalocation).
This is the code in my DLL:
TESTDLL3_API char* bounceString(char data[])
  data = "Hello World";
  cout << data;
char* pointer = data;
return pointer;
However, this function will not be recognized by TestStand 😞
When this is working, I think I can build the rest of the functionality by myself.
Thanks in advance for any help!
Jeroen
The Netherlands
(10,164 Views)
Hi Jeroen,
Have you ever looked in TS-Example foulder: Examples\AccessingPropertiesUsingAPI\UsingMFC
In this Example there is a hole Visual Studio Project. Maybe you can use this for starting on scratch.
For passing strings back to TS, you should take a look on the CVI c-code Example in
Examples\Demo\C\Auto.c "Ignition_Test(xxx)"
Hope this helps
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(10,145 Views)
Sadly, in the example there is no return value to TestStand.
However, I did manage to return the pointer of the char array to TestStand:
int __declspec( dllexport )  bounceString2(char* argument)
  void *pointer;
  int i;
  argument = "Hello";
  pointer = argument;
  i = (int) pointer;
  return i;
So, right now I have to find out how to retrieve the char array from the pointer...
Jeroen
PS, I will look at the CVI code, and let you know about my process
(10,143 Views)
Accepted by topic author Jeroen_Mechatronics
Fixed it 😄
It turns out, I had to declare a string variable in TestStand.
TestStand:
declare Locals.Text (string)
call the DLL module, with arg1 = char[1024] = Locals.Text
After calling the DLL, Locals.Text becomes Hello :D:D
Visual Studio DLL code:
void __declspec( dllexport )  bounceString2(char argument[])
  strcpy(argument, "Hello");
Anyone, thanks for the help!
Jeroen
(10,135 Views)
Just to expand on this for anyone who finds this post later.
TestStand doesn't support functions that return char* because it can't deallocate the memory. So if you need a string back, it has to be passed as a parameter.
See this post by a TestStand devloper for more info:
http://forums.ni.com/t5/NI-TestStand/TestStand-pointeur-en-valeur-retourn%C3%A9e/m-p/904912/message-...
Josh W.
Certified TestStand Architect
Formerly blue
(10,124 Views)
